We ended up and just buying a iKamper to replace the last one. I'm trying to set stripe lights with the adhesive back, but they keep falling off. What is the best tape or glue to use that won't peel off?
I would tape off the area you want stick the lights to, and then scuff it up with some light grit sandpaper. Then use the brake cleaner, then hot glue or the adhesive if it has.
