TerraTamer
Hey all, I'm moving to a larger wheels, but if I go to larger spare, it's going to create problems. Do any of you NOT have a spare tire?
DAMN! So would that Glue Tread patch that?
Not sure how it would fair on this sort of hole, but you want to watch an impressive trail test with these patches, take a watch to this:
This happened on a smooth dirt road about 4 hours from home. Never found what I hit.
If your vehicle came with a 28" tire and you went to 31". That's pushing it if you need to drive on the freeway.
Open diff and part time, Put smaller on front.
Older open diff vehicles will heat up the rear diff over time at high speeds, unlocked front hubs will just pull to the smaller side.
The electronics on newer vehicles will yell at you. Worse case is you pull the ABS fuse.
Limited slip will burn out over time because of the constant slippage.
AWD will burn out the transfer case center clutch over time.
Damage wise, depends on the vehicle and the difference in size.
Even if you have a full sized spare, I recommend you carry a good Tire Plug Kit and a Glue Tread just because.
Why not? It's an insurance policy, if it works and gets you back to pavement, what would you have to lose?No way in hell would I trust one of those patch kits. I'll stick to the spare tire.
