Issues with going with a 4 inch lift rather than a 2 inch?
UtahOverland Well-known member Dec 3, 2021 #3 All the other areas you will need to tweak in order to make the 4 inch lift work properly
Sam Mills Well-known member Dec 4, 2021 #4 I ruins the geometry of everything. Therefore, you will have to do other expensive mods to bring everything back to the correct angle
