Will silicon be good for glueing solar panel to roof?
Martin Cunningham
A flexible solar panel, - can this be glued to rooftop tent with clear silicon? The silicon is waterproof, just not sure on strength if that has what I need?
Mine is easy that size. I put 3 screws on the leading edge. I dont want to find out after a long drive that the air got under the panel somehow and lifted it.
Pretty much all the outside walls on my teardrop are held in with that adhesive.
mines flat facing up. Its a coin toss where you put it. There's no real optimal spot. Most of my trips are desert with the sun overhead. If I go where there's shade, I tie in my portable panel.
