What are the benefits of coilovers?
Nate & Liz
When you compare our trucks having shocks and springs vs having coilovers, what are the benefits of having coilovers?
Assuming your not talking about a factory strut but converting to a coil over system.
Its a single unit. Easier to swap springs around, easy to set up and tune dual spring rates. Can have longer travel.
Empties your wallet faster.
It's a great question! Coilovers can be a game-changer for many truck enthusiasts, and here's why:
  1. Adjustability: One of the coolest things about coilovers is their adjustability. You can tweak your ride height to the perfect level, which isn't just about looking good (though, let's be honest, that's a big part of it). Adjusting the height can also improve your truck's performance, whether you're off-roading or cruising on the highway.
  2. Improved Handling: Coilovers are designed to offer a tighter, more responsive driving experience. Thanks to their design, which combines the spring and shock absorber into one unit, you often get a more precise control over handling dynamics. This means less body roll in corners and a generally more planted feel.
  3. Customization: With coilovers, the level of customization is through the roof. You can fine-tune your suspension setup to exactly what you need, whether it's softer settings for a smooth ride or stiffer settings for better handling and off-road capability. Plus, many coilover systems come with adjustable damping, so you can dial in your preferred balance between comfort and performance.
  4. Improved Stance and Aesthetics: Let's not forget the visual aspect. Coilovers can lower your truck, giving it a more aggressive stance. This isn't just about looks; lowering the center of gravity can also improve handling. Of course, if you're off-roading, you might be looking to raise your truck for better clearance, which is also possible.
  5. Weight Savings: Coilovers can be lighter than the traditional shock and spring setup. This weight saving might not be huge, but in the world of performance tuning, every little bit helps.
That said, coilovers might not be the best choice for everyone. They can be pricier (as already pointed out) and, depending on how you use your truck, might not offer enough of a benefit to justify the cost. Plus, the adjustability, while awesome, does mean you need to spend some time dialing in your setup to get it just right. But if you're keen on tweaking your ride for better performance or aesthetics, coilovers are definitely worth considering!
