Upgrading to an aftermarket steering damper, do you think it is worth it?
If you are running bigger tires yes it is mate. If not it may not be worth spending the money unless the one you currently have is worn out
In most cases, aftermarket steering dampers are needed when going for larger tires. A lift kit alone does not require them
