Size upgrade? How larger should I go on a 5th gen runner?
Sam Mills
What's going on guys?
I have a quick question for you. I have a stock 4runner TRD pro which I am planning on building out to do some overloading and the odd off road trails here and there. What would you suggest is the optimal tire size for this kind of driving?
Because of the IFS I wouldn't go beyonds 33s. It puts too much strain on the CVs and ball joints. if you d some additional mods such as aftermarket arms and ball joints then it will be fine. Is it worth the money though? It depends on what terrain you will be driving really
33s bro. You will be stressing the vehicle and wasting fuel for no reason. Unless you are planning on hitting the hard stuff
Beware of tire rub during sharp turns with 35's on the front. You'll likely need to make some adjustments to prevent.
