Proper way to clean solar panels?
A good quality panel on your offroad rig should be able to be washed just like your truck, soap and water.
Same here, soap and water does the trick here. I will use a microfiber cloth to dry off after though, just to make sure I remove potential water stains from our hard water.
Mine are washed at the same time as the rest of the truck. But I will go through afterwards and dry off quick to avoid as previously mentioned water stains.
