Installed Wilwood brakes on 2020 Tacoma, brakes are soft!!
Chris B Offroad
I just installed a set of Wilwood brakes on my Tacoma and bleed them as I have always done when installing. I went for a test run, and these are still soft. I should add that I tried to bleed the brakes twice now. Usually if brakes are soft, there is air in the line. But I'm not seeing anything here. Any thoughts what this could be?
Thank you for your help!
Chris
Did you bleed them correctly mate? That is nearly always the sign of air in the system. You need to make sure all the air is out!
They need good bleeding when they have been pulled apart completely mate. Get a friend to sit inside and do a proper job
