Fuel storage
Fuel storage
GunRunner
Just curious, when it comes to fuel storage does anyone happen to know why there are no other options than Rotopax that have mounting? I know there are Jerrycans, but that's not the same.
Why no other options?
I'm using Rotopax. The problem is there is no really good alternative to their mounting system. The only thing I don't like is the funnel and how long it takes for the gas to exit the can.
One other option not yet mentioned that you can consider would be long range fuel tanks added to your truck. Look up 'Long Range America', these can in some cases double your range.
These are great options. I've been toying around with getting one. Considering these trucks don't get the best MPG, the range is appreciated.
Rotopax is the way to go, their nozzles suck, but there are aftermarket ones that are much better. Search Amazon.
I use both Rotopax and Jerry Cans, heck if you want to get technical, I even have simple red gas cans from Target.
Rotopax I want to say has patients on the mounting system, which is why you don't see others jumping in. Additional you have the EPA and CARB compliance that keeps others from entering as well.
