Does anyone here use limit straps?
George Redwood
Do you guys use limit straps on your rig? I have an issue with my coils dislocating and would like to limit down travel. Where did you mount them on your vehicle?
I do in the rear. My springs do no dislocate by I use the just to preserve my shocks. I welded two bracket on the axles and two directly above them. It kind of depends one your car and where you can weld bracket on
I find the easiest way to use them in bolt them straight onto the shock mountings (just pas the shock bolt through the clip) Before you mount them just measure the fully open length of the shock and subtract the amount you want to limit down travel
Have not used them before but I know they work well for limiting droop. They are also affordable so when you find a good mounting spot just go for it
