Discovery 2 reliability
Tom Davis
Any landrover experts here? I am looking on some information on the reliability of the Disco 2. I am planning on buying one for overlanding and off roading but i've heard some horror stories regarding the V8s.
What should i look out for? and are they as bad as they say they are?
thanks guys!
Hey Tom, the V8s do have engine issues. Mainly head gasket and oil pump failures. You should also give the suspension a good look as the rear uses airbags that can be problematic.
The three amigos are also a common failure and can be diagnosed by illuminating ABS, hill descent and traction control lights. In most cases it is just a wheel sensor that leads to the issue.
As they are needy vehicles i would take one to a mechanic for an inspection before buying. If you go for a well maintained one you will probably be fine. From my experience they aren't as bad as most people say. Expect to spend some money on it though, it's not Japanese.
