Big tire issues
Big tire issues
Jeep Dave
So I have fitted some big tire on my Jeep and now I have some contact under full articulation on top and on the side of the fenders. I would like not to do any cutting. Is there a way to limit the wheel's upward travel just so it doesn't come in contact with the fenders? Or should I just buy new larger fenders?
Get extended bump stops or give the truck a few more inches of lift by using spring spacers. Spring spacers solved this issue for me bu keep in mind that if you keep the stock shocks you will be loosing wheel articulation
Try longer bump stops that will help stop the wheel before it hit the fenders. However, being that you have the issue on a jeep and the fenders are so easy to swap out I would just change those
