Adding walls to a Space Trailer?
I'm sure it's possible, but I'd be concerned about the suspension first. What you plan on hauling?
I've watched a number of videos on this trailer and I believe you can add the walls if you wanted, but if something goes wrong, and that trailer is new for you. You might void the warranty on it. Something to consider. These look very well made, but are likely designed to be used as they are, and buy modifying as you are after, this will make a mess if anything goes wrong.
How is that even possible? We have been looking at these trailers and there are no side holes that you can place studs down for higher wall support?
I'm not sure how you would get the walls secure. I was watching some videos on this trailer and look at this screen shot
You will need to build a subframe in the inside in order to keep the walls up.
